Data saving with time
Hello Mr. GerdW,
Greetings. I beg pardon for my ignorance. I can't find out two vi (red circled in attached picture) of your picture. Would you please help me to find out those?
Message 11 of 16
(1,809 Views)
Hello Mr. Jeff-Bohrer,
Greetings.
1. I followed your solution (for express vi) but I got a strange time column. All time values are same. Picture has been attached. Would you check please?
2. You showed a date-time formatting example. Actually I can't understand where will I use that. I have attached a "vi" that I followed. Would you check please?
Message 12 of 16
(1,809 Views)
Accepted by Chowdhury_Milon
What you have there is a timestamp in numeric format.
In Excel
  1. Highlight the column
  2. Right click and select Format Cells from the pop-up menu
  3. Select the time or date format you want
=== Engineer Ambiguously ===
Message 13 of 16
(1,802 Views)
Hi milon,
those are waveform functions, you will find them in the waveform functions palette...
Message 14 of 16
(1,798 Views)
Greetings.
You forgot to change to the xlxs file type.  You cannot change a "Date Format" in a binary file type.
Message 15 of 16
(1,790 Views)
Hello Mr. GerdW
Greetings. I followed your method. but couldn't complete the code. I have attached the code here. Would you check please?
Message 16 of 16
(1,780 Views)
