Data transfer between LabView and VB.net
I want to have two applications running, one labview and another vb.net. The LV application consists of two controls a,b & one indicator c.
The logic is a+b=c which is a WHILE loop. From VB.NET I want to pass values of a, b to LV and get back the result 'c' may be through event structure in VB.NET.
Please let me know how to achieve this.
Message 1 of 9
(6,673 Views)
Hi!
Here you can find a starting point for .NET event handling in Labview:
https://forums.ni.com/t5/Developer-Center-Resources/Register-Callback-VIs-for-NET-Events-in-LabVIEW/...
You could,as an alternative, use Labview to build a DLL and call it from VB.NET or vice-versa.
As a third alternative the programs can communicate via TCP/IP or UDP or through a web service.
Marco
Message 2 of 9
(6,642 Views)
I am looking for solution using activex server  in LV. Actually I am able to create LV activex server and register it with vb.net.
In fact I am also able to start the VI and see that the while loop is running. But unable to pass values to the control a and b.
Can somebody explain me using activex server properties & methods how to pass the values to controls.
Rgds,
Message 3 of 9
(6,626 Views)
There should be an example for you, as noted in the last paragraph of this link: https://www.ni.com/docs/en-US/bundle/labview/page/activating-labview-as-an-activex-server.html
Marco
Message 4 of 9
(6,607 Views)
Marco, ur support is appreciated !
However the example is for visual basic 6. Also I know how to call dll, exe from vb.
What I am trying to do is use the methods & properties ( OOPS ) of Virtual Instrument / LV application to transfer data.
The attached screenshot will help you understand my problem better. Here I am trying to stop the execution of counter increment logic in LV from vb.net
Can you suggest solution ?
Message 5 of 9
(6,603 Views)
Hi!
In sub Button1_Click you are defining and initializing local va1 and vi1.
That's probably why the Button2_click is not working as you want.
Always use the global va1 and vi1 and everything should be fine.
Marco
Message 6 of 9
(6,590 Views)
Accepted by puneguy
Yeap U r right !
Thank you Marco.
Message 7 of 9
(6,577 Views)
Glad to see you solved your issue!
If you want you can provide some beer kudos.
Marco
Message 8 of 9
(6,573 Views)
My pleasure !
Message 9 of 9
(6,558 Views)
