Data transmission from a HP 4194A Impedance Analyzer is extremly low since updating to LabVIEW 7.1
Sumit:
Martin has not been active here in over 2 years.
If you are looking for LabVIEW drivers for this instrument, see here:
http://sine.ni.com/idnetwork/main/p/sn/n25:FH?q=4194A&x=13&y=12
The first is for LV 8, the last is for LV 7.
Hope this helps.
Message 11 of 18
(1,601 Views)
Hi..
many thanks. But I can't check it untill next week. I inform U later.
Thanks again
Sumit
Message 12 of 18
(1,592 Views)
Hi there,
Can I obtain a piece of code which deals with sending (array) data to a PC?
thanks
Message 13 of 18
(1,504 Views)
Hi jdownarzap2,
Could you please elaborate on what exactly you want?  Where is the array of data coming from (I assume an HP 4194A), and how is it being transferred to the PC (serial, Ethernet, GPIB, etc...)?
Message 14 of 18
(1,487 Views)
It is very simple.  If you want the "A" array data, send "A?" then read the data.
Message 15 of 18
(1,485 Views)
thanks,
One more thing ... where can I get the array of actual frequencies of the sweep?
(I would prefer to read it from the instrument rather the calculate it an assume...)
Message 16 of 18
(1,473 Views)
I was never able to get that info from the analyzer.  I always calculated it.  Not ideal, but the only solution I could find.
Message 17 of 18
(1,468 Views)
Thanks again...I will stop searching for answer (wasted already a day)...
appreaciated...
Message 18 of 18
(1,464 Views)
