Data type error in property node
I am trying to access the data in the IRegNumeric from property node in VI shot below. the property node can display Comment and Type for every register index 0-999. The RegFloat (real) and RegLong(integer) registers when displayed in the property node, I get data type error. The reason for that is, I have to identify the type of the data before I read it. I can  read one at a time either the RegFloat or RegLong only if I select the right register data type (Real or Integers) . I tried to resolve it by passing to case structure, but still get data type error.
If anyone has idea how to resolve this issue, I will be gratefully appreciated. Thank you.
(3,804 Views)
deleted
Bill
CLD
(Mid-Level minion.)
(3,790 Views)
Accepted by interedo
It was much simpler than I thought, I was trying to pas reference from property node to case structure, simply open property node for each item. may be there is another way.
(3,777 Views)
