Data types do not match
Data types do not match however, in the source that I'm trying to replicate, there seems to be no problem.. Please help. Smiley Sad  Btw im trying to replicate a Amplitude shift keying vi
Thanks! Smiley Happy
P.S. Picture attached is my source.
(4,730 Views)
Share the VI in 2011 format
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,724 Views)
Let's assume that the cluste diagram costant is correct for the subVI (sorry, I don't have your toolkit)
First, to convert real to complex, just use "to cdb" or even wire directly to the bundle node and it will coerce to complex. Note: you need to wire the array to the bottom terminal, because that's how the elements are ordered in the template.
It could look aas follows:
(4,692 Views)
