Remove a picture control's frame ?
I have an app where I need to place several 200x200 pixel picture controls on the front panel.
I would like to remove the standard frame/border so that only the content is displayed.
(6,653 Views)
Accepted by topic author Ben_01880
Use the picture from the classic pallette and use the paint brush tool to color the border transparent (T).
Ben
(6,652 Views)
Can it be done programatically?
(5,133 Views)
Directly not. But you can do some tricks to emulate a frame around your picture control. One possible way is to use a decoration, like the "Raised Frame": create a Frame decoration, and put it around your Classic Picture Control. Make the frame of the Picture Control invisible (brush tool). Now you can programmatically make visible or invisible the Frame decoraton around your picture...
Edit: note that, the code below acts on ALL decorations in your Front Panel. You can get more info about decorations here:
http://digital.ni.com/public.nsf/allkb/FF09C4E6BD4546458625704A004C6ED9
(5,126 Views)
