DataSocket Select URL VI crashes LabVIEW if you inadvertantly drag an item
Run the DataSocket Select URL.vi
Select a server and drill down to an item.
Drag the item onto another item or folder.
LabVIEW crashes without a way to catch the error.
Message 1 of 9
(5,751 Views)
Which version of LabVIEW are you running.  I just tried this on LV 2009 SP1 are did not reproduce the behavior you're reporting.
Justin Parker
Product Support Engineer
Message 2 of 9
(5,731 Views)
Hello, I have the same problem sometimes just by double clicking in a folder. On the developer computer it gives me the default windows error message that "Labview 9.0f3 has encountered a problem and needs to shutdown" and on the test computer just with the executable it gives a different window saying that "Visual studio has encounterd an exception" is there a way that I can fix this?
Message 3 of 9
(5,696 Views)
Hi Bertha,
Do you get any information on the crash the next time you start LabVIEW?  If you did make sure to send the error report to us so that we can track the issue.
Justin Parker
Message 4 of 9
(5,680 Views)
Here is the Microsoft error I get
18891i33BC9EEE04DC0CCA
It has to do with the MSVCR90.DLL. I looked for problems with this library on the discussion forums but no one came up with a solution.
Something similar to my problem is  here
Do you know of any problems with this library and Labview?
Message 5 of 9
(5,585 Views)
When you start LabVIEW after the crash, does it give you a dialog asking if you would like to report the error?
Justin Parker
Message 6 of 9
(5,574 Views)
If I am in the development system, it just asks me if I want to recover the project but it does not ask me to report the error.
Message 7 of 9
(5,567 Views)
This Select URL dialog still crashes or hangs sometimes in LV 2014, but at least now there is a CAR, number 548355.
Also, this dialog is ridiculously small for real-world URLs, such as OPC Servers. Please kudo my suggestion to make it larger / growable on the Idea Exchange.
Message 8 of 9
(4,889 Views)
CAR 548355 has been fixed in LabVIEW 2016. Please see the LabVIEW 2016 Bug Fix List for more information.
Message 9 of 9
(4,726 Views)
