Showing results forĀ
Search instead forĀ
Did you mean:Ā
Database Connectivity Error: ADO...?
I am trying to export data into a local Oracle database using the Database Connectivity toolkit.
(I have created my table TEST in the local Oracle database, I can access it, write to it, read from it, etc. using SQL. I also have .dsn file that works with SQL)
I get the following error:
(4,477 Views)
It sounds like the issue is with your connection path.  I would try to check to make sure that is correct first.
TimC
Applications Engineer
(4,443 Views)
Check the user and password in the Open connection. It looks like one of those errors.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,436 Views)
Accepted by murchak
I found the problem. Not related to LabVIEW (Duh...).
Basically, I have two copies of the .tns names in two different folders. One of the files that I was using to establish a connection
to the database didn't have the correct connection info and the other one did. The one that did was the one that I was using.
(4,421 Views)
