Database Connectivity Toolkit (multi row insert)
Just a guess: are you sure you can use comma as decimal separator?
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 31
(3,483 Views)
Now that you have no quotes on the float, your issue is probably the comma as a decimal separator.
aputman
Message 12 of 31
(3,483 Views)
I had the same error even before adding the channels table when I was trying to insert just the values ( My query was : insert into mesure (valeur) values(%f); ) .
Message 13 of 31
(3,480 Views)
Right.  And if you have a comma separator, your query looks like it has two input parameters.
Insert into mesure (valeur) values (13,935527);
13 is one input parameter.
935527 is another input parameter.
That's why the period is the superior decimal separator.  Smiley Very Happy
aputman
Message 14 of 31
(3,473 Views)
Obviously. And won't you try using a period as decimal separator?
Just prepend %.; to your format string.
Paolo
Message 15 of 31
(3,470 Views)
I tried that, no difference except that I have the error with a period now instead of a comma
Message 16 of 31
(3,465 Views)
It seems that your query ends with the substring "insert i": where does it come from?
Paolo
Message 17 of 31
(3,457 Views)
I think it's just due the error message (window too small for the whole message) and it has nothing to do with the query. My query is just as shown in the string constant.
Message 18 of 31
(3,448 Views)
Look in your ODBC connection settings.  You may have to enable multiple statement queries.  Otherwise, anything after the first semicolon is a syntax error.
aputman
Message 19 of 31
(3,432 Views)
Here:
aputman
Message 20 of 31
(3,425 Views)
