Database Installer LV8.6
Hello, I am getting ready to build an installer for my application and it uses the Database Toolkit 1.0.2 I looked at the instructions on how to add all the necesary files to the installer(link bellow) but it asks for "Database application template.bld" in the LabVIEW/database directory. I can't find this file. Is it really needed if you use LV8.6? and if it does where can I find it? do I have to reinstall DB Toolikit? I'll appreciate the help. Thanks
http://digital.ni.com/public.nsf/allkb/45A21AF2AE0A61D88625719B0050958D
(3,503 Views)
Accepted by Bertha
If you do not have a build script from an old LabVIEW 7.1 project then that KB is not applicable. If you want to build in installer in LabVIEW 8.6 just use the normal steps. All you should need to include is the LabVIEW runtime engine itself.
(3,472 Views)
You may need to include the UDL/DSN file into your installer if you have.
(3,447 Views)
Thank you for the help, I just created the executable and installer as I have been doing and it worked. The database toolkit manual was not very clear aboit it and then I couldn't find any information about it thanks
(3,423 Views)
