Database connection.
Hi, I want to connect an access database with the connect VI's, how do i
create a datasource?
(3,118 Views)
i>create a datasource?>>
Which tool you use? For XON's DAO Toolkit (www.xon.de) you simple need to
give the path for the mdb-file. Otherwise, you create a datasource (within
NT) in SystemControl-ODBC, there you can create a DataSourceName (it just
saves the Database Name and some opening options in a file. Hope this helps...
Peter
(3,118 Views)
