convolution
I need to implement a convolution integral system in labview and have
been trying to write the program using the Convolution vi by feeding it
two arrays of numbers after generating them using a FOR Loop.
Both the functions are time based functions.
The problem is that if I use different time steps to generate the arrays
(ie 1ms to 100ms ) then the convolution function gives me a plot which
has the same shape but completely different amplitiudes.
Do I need to apply a correction factor in the convolutin vi to adjust
for the time step?
Can someone help me ?
my email address is
sekhar@mail.utexas.edu
thanks
Chandrasekhar
Message 1 of 1
(2,963 Views)
