Database connectivity toolkit problem with WINDOWS VISTA and Microsoft jet 4.0 provider
Hi again,
I'm experiencing a problem with Database connectivity toolkit and Microsoft Jet 4.0 provider (MS ACCESS mdb database).
I was able to get my application to work properly on my PC: WINDOWS XP PROFESSIONAL, VERSION 2002, SERVICE PACK 3 and Msjet40.dll ver. 4.0.9511.0 (Windows XP SP3 and Security Bullettin MS08-028).
The same connectivity toolkit seems to have problems (although I didn't get any error dialog) on a laptop with WINDOWS VISTA ULTIMATE, SERVICE PACK 2 and Msjet40.dll ver. 4.0.9755.0.
Does anyone have an idea whether it is a sort of compatibility issue or a different thing?
Would it be possible to include my DLLs into the installer in such a way LabVIEW application calls those DLLs instead of the ones it finds on the host PC?
Thanks a lot. Any suggestion or advice very welcome and appreciated.
(3,589 Views)
Hi Blueyes,
What version of LabVIEW are you using on each machine?
- Greg J
(3,560 Views)
The application has been built with LabVIEW 2009 and then installed on the laptop.
I didn't install LabVIEW development environment on the laptop but only on my workstation.
(3,549 Views)
I ran into this with Windows7 64 but, could not get the jet 4.0 to work.  Endnd up dumping access and used sql server express, its free, and all my code worked fine, just used a different UDL to connect.  I wasted lots of time trying to find a way of getting the jet4.0 to work with 64bit windows.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,540 Views)
