Defaultly open a blank tree
I had constructed a tree to display data in 2- columns with parent and child nodes. But the problem I have is if i run the vi and close it, for the next time if I open the vi, the previous data is defaultly shown in the tree structure, instead of displaying a blank tree. Can someone tell me how to set the tree to be blank when ever I open it.
Thank you,
Raghu
(4,290 Views)
Use the invoke node to delete the Item... Give True value to Delete child item...
Smiley Wink
(4,271 Views)
Iam already using the invoke node to delete the items but its still holding the values in the memory, and when ever I open the vi, the last executed values are dispalyed in the tree. Can you please take a look at this attached vi and tell me if iam missing any thing.
(4,245 Views)
No, you are not missing anything.  That is the normal behavior for a tree control.  Likewise for a ring control.  You are not changing the value of the control.   But you are programatically changing the properties, in this case the Items.
(4,233 Views)
So, Ravens there is no way to display a blank tree when ever I open it? This is really important for me to display a blank tree before i run it. If there is any alternative can you please suggest me.
(4,228 Views)
Yes.  Run your VI up to the point where it deletes the items.  (Use a breakpoint to stop it.)  Clear the breakpoint and save it.  Now the VI is saved with all the items deleted out of the tree.
Or just go with what you have now which is clearing the tree at the very beginning of your program.  But your program continues on and happens to repopulate it.  If you correct the spelling of the word "group" in your array, you'll see the tree does get cleared out with the misspelled words and is recreated with the correctly spelled word.
(4,220 Views)
