Datasocket?
How can I communicate with Datasocket in a LAN
network.
I have two computers connected with LAN
I use LabVIEW 6i
Richard
(3,401 Views)
Hi !
Have You read the datasock.pdf file in
%systemroot%\Program Files\National Instruments\LabVIEW 6\manuals
It should give you a clue !
Yours/
Roger Öhlund, MSc Engineering Physics
Lovsele 83, 930 10 Lovanger, Sweden
Tel. +46 70 3333543, +46 913 41041
angler@acc.umu.se
angler@mail.bip.net
"RICHARD PETTERSEN" wrote in message
news:dVTS5.788$l43.90275@juliett.dax.net...
> network.
> I use LabVIEW 6i
> Richard
(3,401 Views)
datasocket is made for this. You set up the datasocket server with your
IPs (or node names) and then it is very straight forward to use the VIs
on the palet to transfer data between LabVIEW programs.
Jim
> network.
> I use LabVIEW 6i
> Richard
(3,401 Views)
