im/export of C-code
I wonder if it is possible to import C-code into a Labview-project or if
it is possible to import a Labview-project into a C-program.
Thanks for your help.
Sent through GMX FreeMail - http://www.gmx.net
Posted from www26.gmx.net [213.165.64.76]
via Mailgate.ORG Server - http://www.Mailgate.ORG
(3,412 Views)
You can...
import:
- create a labview code interface node based on your C code
- create a DLL from your C code
- create an activex with your C code
export:
- enable the labview active x server when building an executable
- create a DLL from your labview (version 6) code
- use the helper methods from NI to call LabVIEW VIs from Visual C++ using MFC
.... what is missing in this list?
Martin
Martin Henz Systemtechnik
Dipl. Ing. (FH) Martin Henz
Rochenweg 1
70378 Stuttgart
Tel. ++49-711-5302605
Fax ++49-711-5058649
http://www.mhst.de
(3,412 Views)
