Single data and waveforms
Hi all,
I just got my upgrade to LV 6 and I'm starting to dive into it. I have a
question which I think has two possible solutions. I get results every
30 seconds from a voltmeter through a GPIB card, and I want to display
the waveform on screen, with and without filtering. I've found filtering
very easy to perform on a Waveform data type, but I don't know how to
add single values of data to my waveform. So my question is:
- Is there an easy way to append data to a waveform as soon as it is
collected (so I can filter it easily), or
- Should I have my data in an array, append the data to it, and perform
filtering on it too?
Thanks for your help,
Jordi Felices
Jefe de Laboratorio
Household Technologies, S.L.
C/ Argenters, 7
Parque Tecnológico del Vallès
Cerdanyola del Vallès 08290 -- Spain
Tel. 34/935 824 306
Fax 34/935 824 407
Email: jordi.felices@house-tech.com
(3,012 Views)
Hellow Jordi,
you can solve the problem by using FIFO buffer.
I'll send an example to you directly
Best Regards
Mike Manzheliy
Automated Control Systems
"jordi.felices" wrote:
> Hi all,
> Jordi Felices
> Jefe de Laboratorio
> C/ Argenters, 7
> Tel. 34/935 824 306
> Fax 34/935 824 407
(3,012 Views)
