Date/Time <---> String
tst a écrit:
Actually, if I'm reading my calculator correctly, and allowing for it being a signed number, shouldn't that be about 275 billion years in each direction (and I realize I may be unnecessarily splitting hairs)? Anyway, I understood that this was already changed in 8, so that should be better.
And just to restate the point of the thread - we want a vi.lib String to Timestamp function!
They couldn't keep 32bits for the number of seconds because it would not have solved the 2038 limit. Jumping to 64bits was a natural choice, even if it leads to ridiculous ranges (2^-64 hasn't physical meaning either).
Quiz: which day of the week will the LabVIEW timestamp overlap? Smiley Wink
LabVIEW, C'est LabVIEW
Message 11 of 19
(2,468 Views)
You can use the Scan time string function in my Time package. It accepts a format string like at the Format Date/Time function. Also does timezone handling.
http://robijn.net/labview
Joris
Message 12 of 19
(2,405 Views)
Hi all
How can i put the date/time function into this??
Message 13 of 19
(2,088 Views)
Here is a vi that I use that converts some of my common date strings I get from a database query into a time stamp using the scan from string function.
To put the timestamps into a display like that you will need to change the type from a chart to a graph form.
If the time is not at constant intervals you will need an x-y graph type, see the help for more information on how to bundle time with Y values.
If the time is at constant intervals you can use a waveform graph type instead.
Message Edited by Karissa on 08-04-2008 02:10 AM
_______________________________________
Systems Test Engineer
Certified LabVIEW Architect (CLA)
Message 14 of 19
(2,080 Views)
Hi Karissa
Thanks for the example u gave. I was wondering if it is possible for me to use the numeric control to choose my year,month,day and hours instead of wat u sent me??
holla
Message 15 of 19
(2,073 Views)
Hi holla,
where in your code you want to insert this Date Time function? To use controls for the day and time and ... you can create a cluster and transform it to a timestamp.
Mike
Message Edited by MikeS81 on 08-04-2008 09:44 AM
Message 16 of 19
(2,066 Views)
Hi
When i press stop, it will prompt to save the file for example in notepad. So I want the time to be in the notepad. Leave the numeric buttons first
holla
Message 17 of 19
(2,061 Views)
Hi holla,
do you meas as part of the values in the file or a part of the filename?
Hope it helps.
Mike
Message 18 of 19
(2,051 Views)
Hi
Its as part of the values in the file.It something like this.
Message 19 of 19
(2,047 Views)
