Date Verification
In Labview 7.1, how can you
-display the current date on the front panel
-allow user to edit the date
-verify that it is a valid date
(3,272 Views)
The simplest solution is to use a time stamp control, since the time/date format are automatically managed. You can then add an "In-range" comparison node to fix the upper and lower acceptable values.
See the attached vi.
Chilly Charly    (aka CC)
(3,259 Views)
Thanks for your help.
That does the trick.
(3,249 Views)
