Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Date Verification
Date Verification
D. Mac
Member
06-06-2005
01:37 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
In Labview 7.1, how can you
-display the current date on the front panel
-allow user to edit the date
-verify that it is a valid date
0
Kudos
Message
1
of 3
(3,473 Views)
Reply
Re: Date Verification
chilly_charly
Trusted Enthusiast
06-06-2005
02:39 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The simplest solution is to use a time stamp control, since the time/date format are automatically managed. You can then add an "In-range" comparison node to fix the upper and lower acceptable values.
See the attached vi.
Chilly Charly
(aka CC)
Check time.vi 21 KB
1
Kudo
Message
2
of 3
(3,460 Views)
Reply
D. Mac
Member
Author
06-06-2005
03:07 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for your help.
That does the trick.
0
Kudos
Message
3
of 3
(3,450 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
