Date and time stamp in array
I am using Labview 8.0 and I would like to include a date and time stamp each time data is collected and include this as a 5th column in the final array.  I inserted a random number generator instead of devices so it would be easier to understand and test.  I am new to Labview and have never created a date/time stamp before.  Any help or advice would be appreciated.
Dave
Message 1 of 19
(8,412 Views)
What format do you want the date time stamp. Is second since 1904 ok or do you actually want the date?
Tim
GHSP
Message 2 of 19
(8,404 Views)
Here is a simple example.
Tim
GHSP
Message 3 of 19
(8,397 Views)
Either format is fine, whichever is the easiest to understand would be best.  I couldn't open the example with version 8.0.  It must have been created with a later version.
Dave
Message 4 of 19
(8,385 Views)
Accepted by Dave01
Here is an 8.0 version
Tim
GHSP
Message 5 of 19
(8,377 Views)
while we are on this topic.
what does it mean by date or seconds since 1904?
why does labview uses this date?
Krispiekream
Message 6 of 19
(8,372 Views)
Everyone has to pick a standard. Microsoft uses seconds since 1901. It is just a starting point but it is very important to know the differences between systems.
As far as the date vs. seconds since 1904, I would store the date as a string so that I could convert it to what ever I need it to be. It makes saving the data a little more difficult.
Tim
GHSP
Message 7 of 19
(8,366 Views)
The 1904 date was used by Apple.  Since LV was originally developed on the Macintosh, NI used Apple's convention.
Lynn
Message 8 of 19
(8,356 Views)
This solution worked fine for saving seconds since 1904, but now that I have been using the program I would prefer to save the time as HH:MM:SS.  From what I have read, I think I need to convert to a string, but I'm just not sure how to do that.  Here is a simple version of my program.  Thank you for any suggestions or examples.
Dave
Version: Labview 8.0
Message 9 of 19
(8,125 Views)
Yes you need to convert all to strings since the timestamp in HH:MM:SS is a string.  In the string palette, there is a sub-palette full of numeric to string conversion tools.  Use the Number to Fractional String to convert all numerical data to strings.  Use the Format/Date Time String function (found in Timing palette) to convert the timestamp to HH:MM:SS.  See the format string in my example.
- tbob
Inventor of the WORM Global
Message 10 of 19
(8,098 Views)
