De-activate EXE License using Third-Party Licensing & Activation Toolkit
Is there a way to de-activate a license file using the functions in the TPLA toolkit? I'm using LV2011 and installed the toolkit. I've called the IP2Lib32.dll successfully to activate but it does not have a way to de-activate manually.  To de-activate automatically, I run:  myProgram.exe\ DEACTIVATE but this doesn't allow for the de-activation to occur from another computer.  Any advice would be greatly appreciated.
(2,889 Views)
I don't know about third-parties but the regular de-activation process is the following...See Document ID: 3TUA30KK
Alejandro C. | National Instruments
(2,877 Views)
He is referencing the Third Party License Toolkit from NI, not some third party licensing! I can't give a solution to his problem, as I know that Toolkit only marginally but it seems to me he wants to use that Toolkit to license his own library and have a way to revoke a license for that library.
Rolf Kalbermatter  My Blog
(2,870 Views)
That's right.  But I'm using the library to license an executable.  The activate/deactivate functionality can be utilized with the InstantPlus software in a number of ways but they all seem to fall short of a complete solution:
1. Injecting the EXE code works only with 32-bit programs
2. Calling the InstantPlus DLLs provides unclear instructions for the end users (if the program is already activated, it asks them if they want to activate, not de-activate, etc).
3. Calling the program with /DEACTIVATE in the command line only works for online de-activation, not through another computer
4. Labview's toolkit doesn't include a deactivation capability at all.
That leaves the InstantPlus API, which is going to require more low-level code work than I was hoping for and I'm still not sure its going to work.
That said, I think the product will be very useful once it gets some kinks worked out.  If anyone has been down this path before and has some advice, I'd appreciate it.
(2,858 Views)
