Deallocate memory as soon as possible option in LabVIEW 7
In LabVIEW 6 (professional version I think), the deallocate memory as soon as possible option is under Tools >> options >> performance and disk. However on LabVIEW 7 (base version) it is not there. Does anyone know where the option has been moved to or is the option AWOL?
(2,987 Views)
I believe they're trying to encourage developers to use the Request Deallocation node (on the Advanced >> Data Manipulation palette) instead. This node will allow you to specify memory deallocation on a per-VI basis instead of globally for all VIs.
(2,987 Views)
As you can read in the Release Notes this option has been removed.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,987 Views)
