Dear Sir/Mam I want to implement Modbus protocol over RS-232 for my sbRIO board
I want to implement Modbus protocol over RS-232 for my SBrio board. is it possible and how ?
(179 Views)
in sbrio 9638 can i use modbus communication, if it's possible how ?
(163 Views)
Hi AJAYY,
@AJAYY06 wrote:
I want to implement Modbus protocol over RS-232 for my SBrio board. is it possible ... ?
Yes.
@AJAYY06 wrote:
and how ?
By writing code.
What have you tried?
Where are you stuck?
Which (specific) software environment do you use?
Did you try any of those ModBus libraries from VIPM?
(155 Views)
Hi AJAYY,
Please stick with your thread instead of creating multiple threads/discussions on the very same problem!
(144 Views)
Accepted by AJAYY06
And why do you want to implement it yourself? There are about at least half a dozen existing libraries that do this in more or less similar ways. A quick search offers these options but I'm sure there are more:
https://www.ni.com/en/support/downloads/tools-network/download.modbus-master.html?srsltid=AfmBOoq1uD...
https://www.vipm.io/package/ni_lib_modbus_library/
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LP9SAM&l=nl-NL
https://github.com/plasmapper/modbus-client-labview
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
https://github.com/NISystemsEngineering/LabVIEW-Modbus-API
And some knowledge article from NI about how it principally works and what are some of their options:
https://www.ni.com/en/shop/labview/introduction-to-modbus-using-labview.html?srsltid=AfmBOooy09PEbKX...
I usually go with the second option above. It has its particularities that I would have solved differently but it does the job and is fairly easy to use.
Rolf Kalbermatter  My Blog
(101 Views)
