Debug mode not available
Hi there!
I am facing a problem I didn't have before: I cannot debug an executable anymore...
In the build specifications windows I:
  • Enabled debugging
  • Unchecked "Remove block diagram" in Source file setting tab.
Yet, I can't access the block diagram once the application is built.
Do you have any clue what could cause this?
Here are some picure of a very simple project showing my issue (also enclosed):
This is the .exe file window:
Thanks in advance for your help.
Vinny.
Message 1 of 1
(1,201 Views)
