NI Max Update
Hi all
Whene I use NI max ,it shows me a warnning message like is shown in  the picture below
any help please and thank you
Message 1 of 9
(3,208 Views)
could you translate the error message to English please
Message 2 of 9
(3,166 Views)
ok
"A problem occurred while updating the parameters of this device.
the operation exceeded the allotted time"
Message 3 of 9
(3,152 Views)
I haven't come across this before, a few questions:
- What parameters are you trying to update
- What hardware are you trying to update (I am assuming you are setting parameters on a piece of hardware)
- Is the hardware ethernet, usb or PXI
- What version of MAX do you have
Message 4 of 9
(3,149 Views)
I didn't update anything that message appears whene I just open the NI Max , also after I refresh the page it appears a message like it shows in picture below
Message 5 of 9
(3,118 Views)
Again, could you translate that second message into English
Personally I don't have many suggestions here, someone else might come along with more info.
I would try repairing MAX using NIPM. This has fixed obscure errors like this for me in the past.
Message 6 of 9
(3,102 Views)
I've seen this.  The MAX database may be corrupted.  To fix it, go to Tools>Reset Configuration Data.  This rebuilds the instrument database.  A restart is required.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QkRSAU&l=en-US
Message 7 of 9
(3,097 Views)
Ok , thank Sir your suggestion solve a problem but it caused a new one . After resetting the configuration ; nothing it appear one I try to add a new network peripheral as shown in picture below.
Thank you
Message 8 of 9
(3,071 Views)
I'm not sure I understand.  When you try to Add Network Device, there is no dropdown selection?  If that's the case, you may need to do as Niatross suggested, and repair MAX.
Message 9 of 9
(3,058 Views)
