Debugging classes
I just started working with LabVIEW OOP and I think I must be missing something about how to debug classes. I can't put breakpoints or probes in class method vis, and I can't step into them. Do I have something setup wrong or is there some other mechanism we are supposed to use for debugging when using classes?
Thanks in advance for the help.
(3,668 Views)
Accepted by LukeMSS
If you make property accessors I believe LV makes them inlined by default.  Check the execution properties and see if debugging is enabled.  You may need to cnahge them from inlined to reentrant to get up and running with debugging like this.
Shane.
(3,649 Views)
Thanks Shane. This solved my problem.
(3,640 Views)
