Decide showing length with property node?
Hello!
We have an array that shows in the front panel. It is very long and we want to be able to see ten elements at a time. Is there any property that we can drag for example number ten to? Or is there another way to do this? Thank you 🙂
(2,939 Views)
Hi, create your array control with 10 cells and use Property Node "Index Values" - this value change initial index of 10 cells on Array control.
(2,934 Views)
Hello Nadav Chernin!
Thank you for your answer. We have tried that. The array in the front panel then go to ten directly? We want to see ten elements (with start from zero to ten and then one should be able to click so that we see from eleven to twenty, and so on...) Any tip or have we done something wrong ?
Best regards.
(2,921 Views)
Hi, please look attached example. Hope that will help.
Nadav
(2,913 Views)
