Decimal to Floating point with ranges
Smiley HappyHi,
I am wanting to convert a Decimal value that needs to be scaled to a floating point value.
For example.
0 to 20000 Decimal value where half is considered the zero point. Then the values either side of this middle value are considered postivie or a negative double (0-10000 considered negative, 10001 to 20000 considered postive). Then the resolution of each decimal value is relative to a predefined scale.
Not sure how to go about this.
Any help is much appriciated. Smiley Happy
(2,714 Views)
Accepted by Eletrostatic
I hope I understood right what you wanted.
Please take a look in attachment.
Paulie
(2,697 Views)
Works fine. Thanks Smiley Happy
(2,647 Views)
