Decoding serial data.
Hi Ravens,
the help to this property says the default is "TermChar".
Mike
Message 21 of 23
(1,479 Views)
Thanks Mike.
You're right.  I missed that when I read it.  I had right clicked and created constant on that property node and it came up None.  When dealing with subVI's, that is a good indicator of the subVI's default value.  I guess for property nodes it is not.
Message 22 of 23
(1,473 Views)
I modified my code so that the "End Mode for Reads" property was set to none and was able to recieve the whole message with one read command instead of two.
Thanks again to everyone for their input.
Corey
Message 23 of 23
(1,444 Views)
