Default values for unconnected sub-vi inputs in LabView RT
Given that LVRT doesn't include the front panel when running VIs, how should default values be specified for control inputs that are left unconnected?
XL600
(3,985 Views)
You're confusing two things. The front panel defaults are still used, there's just no graphical front panel. From the perspective of passing parameters, the front panel controls act normally.
(3,973 Views)
So a property node wouldn't be able to read the default but the default would still be used if the control was left unconnected?
(3,968 Views)
Accepted by xl600
Yes, that's right. It's a side effect of LabVIEW using front panel elements for two different purposes.
(3,964 Views)
Thanks.  I'm sure that's been explained in many other places, but I don't think I've ever seen anyone state it so clearly and simply.
(3,952 Views)
