Define a physical channel in MAX
Accepted by topic author bmann2000
If you explore the DAQmx Property Nodes menu, you will find the following, both methods below work.
The .nce file export from MAX shows you the information hidden inside the Task:
[DAQmxChannel DI_InsideWin1/DigitalIn]
DI.InvertLines = 0
ChanType = Digital Input
PhysicalChanName = Dev3/port1/line0
Once you see this, it's clear that you need to access the Property PhysicalChanName.
Message 11 of 11
(430 Views)
