Defining Project root directory
I'm setting up a LabVIEW (and TestStand, for that matter) project.  I'd like to declare some type of path constant, i.e. 'ROOTDIR', that might equate to C:\myBaseDir\FirstLevelOffset.  Then, in my project setup, when I tell it where to find files, where to place applications when they're built, etc, I can use the ROOTDIR to (1) cut down on the length of the path, (2) our directory structure (root) is going to be in a state of flux over the next month or so.  This would allow me to change ROOTDIR and not affect all my path/project setup.
Does anyone have a suggestion as to how to go about setting up a base path constant?
(4,393 Views)
I dont want to say that it is not possible as LabVIEW is a programming language but I have not come across a way to do it yet.
Ankita
(4,371 Views)
You can use a configuration file (.ini file) to store these settings and LabVIEW's configuration file VIs to access them
(4,366 Views)
Do you have an example of what I would need to do?
(4,361 Views)
Yes:
(4,355 Views)
