Delay between each byte
I was just wondering if there was anyway I can input a delay between each byte with the visa write. For instance in Hex: the command would be FEA0 0000 00A0 , if i can add a 50 ms delay between FE, A0, 00 etc. Or if anyone has a sub VI that does this?
(3,287 Views)
All you have to do is put your VISA write in a loop with a 50 msec delay, and write the message out one character or byte at a time.  If your bytes are in an array, you can autoindex the array.  If they are in a string, pick off one character at a time and put the remainder of the string in a shift register for the next iteration.
(3,281 Views)
See here for my implementation.
(3,275 Views)
Hi Dennis,
Sorry to be a bother but can you show a picture of the serial write slow vi so i can compare it to mine? I have an old version of labview.
(3,245 Views)
Jabano,
Heres a picture of his code.
Kyle Mozdzyn
Applications Engineering
Kyle M.
(3,234 Views)
