TL EL355P - EL302P
Just starting with Labview and managed to get some leds running and get some output on my parallel port.
So I already used the VISA part.
Next step is to use the TTI EL355p / EL302P DC powersupply, connected with RS232.
But I am a bit confused what to send to the VISA input?
I already managed to send *RST and *IDN?, sometimes I get a response and it goes to the *RST mode or gives the output as described under *IDN?
I wired a string to the VISA input and then send for example *RST
The powersupply goes to remote mode every time, baud rate is on 9600
(2,675 Views)
(2,671 Views)
