Delete first rows from array
Hello...please for advice.
I have an array of:
0
0
0
1
2
3
4
5
0
0
0
0
and i wanna delete just first three rows of zero and count how many rows i delete it. This first "zero" values are each time different. Sometimes i have 3 "zero" values another time i have 20 "zero" values.
Last "zero" values i wanna keep like they are.
Many many thanks
Message 1 of 9
(7,319 Views)
That "zero" value is something constant? Known during development?Not a floating number?
If so, you can use a conditional for loop to find the first "non-zero" element. The iterator of that for loop is the number of elements you want to delete from the array, so the length.
Using this approach, you should get a working solution. There might be better performing approaches out there......
Norbert
Norbert
Expert: Geometry
Message 2 of 9
(7,303 Views)
Just to show what Norbert was saying.  I used the Array Subset with the index wired to the i of the FOR loop.  The length defaults to "rest", so everything starting with the first non-zero on will be kept.
Message 3 of 9
(7,290 Views)
Question, are the zeros added to the array because of how the program is written or are they actual data that you want to ignore? Basically, I asking if you are inserting the zeros into the array when you shouldn't be.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 9
(7,269 Views)
Another way, without a FOR loop.  Finds the first nonzero element and deletes everything up to that point.
Message 5 of 9
(7,247 Views)
the zeros are actual data wich i want to ignore.
tnx
Message 6 of 9
(7,237 Views)
This will only work if the first nonzero element is close to 1. If the first nonzero element is e.g. 10000, threshold array used in this manner will give the index of the last zero element.
Here's another alternative.
Message 7 of 9
(7,232 Views)
Ah, right you are.
Message 8 of 9
(7,227 Views)
Thanx for all solutions. Tnx
Message 9 of 9
(7,178 Views)
