Delete multiple rows from table/list control
I want to have a table control in which a user can enter different entries, like this:
My program would read each entry at a time and do something.
However, I would like to give the user ability to delete multiple entries at once, like in an Excel spreadsheet - that is, the user selects multiple rows and presses "Delete" key and those entries get deleted. The Labview table does not allow this it seems - I can only delete one entry at a time - or I have to right-click and select Data Operations->Cut Data, which is awkward.
Is there a control better suited to what I want to do? I tried a Llist control, but it behaves in the same manner.
Thanks in advance!
(5,337 Views)
Accepted by SenSLabs
You could write your own routine.  Use an Event Structure with a Key Down event.  If the delete key was pressed and the table has focus delete the elements that are selected.
(5,311 Views)
Thanks a lot!
Good to know I haven't missed an easier option 🙂
(5,303 Views)
Dear sir,
Please help in this case
suppose i have data
  112233 1 2 3 4
  112233 2 3 4 5
  112233 3 4 5 6
  112233 4 5 6 7
  112244 5 6 7 8
  112244 6 7 8 9
i want to delete  "112233      4        5       6     7   " by selecting row.
or can we delete row by selecting checkbox.?.
need your help.
james Tan
(4,490 Views)
@jamestan077 wrote:
Dear sir,
suppose i have data
  112233 1 2 3 4
  112233 2 3 4 5
  112233 3 4 5 6
  112233 4 5 6 7
  112244 5 6 7 8
  112244 6 7 8 9
need your help.
james Tan
Hi jamestan077,
If you are wanting the user to be able to delete one row at a time, they can highlight the row they want to delete, right click, and select delete data.
Crossrulz also suggested a method above of deleting multiple rows without using the Cut Data operation. Was there a specific method you wanted for the user to be able to interact with a table control?
Best,
David F.
Applications Engineering
www.ni.com/support
(4,476 Views)
Thank you So much,
I am studying so many new things from you.
Thanks a lot..
(4,371 Views)
