Delete or insert a record into a database table
Hello everyone.
I am trying to include or delete the nth record of a table in a database (database connectivity toolkit).
Any ideas?
Thanks in advance.
Message 1 of 11
(8,719 Views)
@labviewette wrote:
Hello everyone.
Any ideas?
Thanks in advance.
DELETE FROM [a table] WHERE [record] = "nth"
Jim
Message 2 of 11
(8,693 Views)
To elaborate on Jim's response:
aputman
Message 3 of 11
(8,686 Views)
Thank you both !
Message 4 of 11
(8,669 Views)
Dear Jim and aputman,
I am not getting this working yet. In the case of updating a record:
If I set the "DB Tools Update Data.vi" condition to be record='10' (for example) then I get error -2147217900.
If t set the vi's condition to be WHERE record='10' then I get error -2147217904.
Message 5 of 11
(8,642 Views)
We were being a bit facetious in our response by setting the condition to be record='nth'.  In order for that to work, you have to have a table named "a table" (which is illegal because of the space...pick a meaningful table name), and the table should have a column named 'record' that has a datatype of char(3).  If the datatype of your column is actually an INT, and you want to update all entries (or delete all entries) that have a 'record' value of 10, you need to remove the quotes (WHERE record=10).  I screwed up in my image and left off the WHERE keyword.
What database engine are you using?  Do you have a table created?  Have you built a connection string that creates a successful connection in the Open Connection VI?
aputman
Message 6 of 11
(8,636 Views)
aputman is right.
I would like to add a possible insert code. Assuming you would like to update a whole row you can just use a cluster as input.
Message 7 of 11
(8,615 Views)
Please share details about the table you want to update: name, fields & data types should get us started.
Jim
Message 8 of 11
(8,595 Views)
Here is an excerpt of the database. The table's name is "table".
How can I update or delete the last record when I do not know the ID?
I am aware that this is more of an SQL than a LabVIEW question.
Message 9 of 11
(8,588 Views)
Search for the record where rowid=max(rowid).
Message 10 of 11
(8,578 Views)
