Delete row (index is comming from an array) from source array
Dear Friends,
I am comparing two arrays and would like to delete rows from the source array.
maybe following VI can explain better what I have in my mind.
I like to delete row :3 6 from missing elements array
I can't put in the same case structure and loop while it makes 3D array.
Regards
Arvin
Message 1 of 15
(5,680 Views)
I am actually more confused after looking at your VI.  It would help if you supplied actual inputs and expected outputs.
Message 2 of 15
(5,651 Views)
(posting by phone, cannot look at VI).
Also remember that after you delete row 3, the values of row 6 will have moved to a smaller index, for example.
Message 3 of 15
(5,645 Views)
my expecting output is be able to delete row 3 and 6
Thanks in advance
Message 4 of 15
(5,635 Views)
thanks for the hint but how can I delete two rows one array programmatically?
Message 5 of 15
(5,632 Views)
sorry for confusions, I'm trying to delete two rows programmatically
Message 6 of 15
(5,631 Views)
In which case deleting starting with the largest index and working toward zero will work.
Arvin,
You did not include the data in the front panel so your question does not make sense.... particularly when you have 2D array not even used in your code and everything else is 1-D.
maybe post in your native language and let us do a Google Translate?
Ben
Message 7 of 15
(5,619 Views)
Try a conditional tunnel
Message 8 of 15
(5,618 Views)
And if the rows to be deleted are sorted, you can start searching from the last found location (+1) to lower the big O complexity. 😄
Message 9 of 15
(5,607 Views)
Adding a "Super CA" ModSmiley LOL Just because I can always do better
Message 10 of 15
(5,596 Views)
