Deleting Numbers less than a threshold from an Array
Hello All,
In my code, it outputs an array of the difference between the peaks in milliseconds the array called PPI's. I want to delete any elements in the array which are smaller than 850. Any ideas on how to do that? I've attached my code for reference, and the data required to make it run.
Regards, Sean
(3,726 Views)
aplogies, this is the latest version of the code
(3,721 Views)
Accepted by seancassidy
Conditional indexing tunnels makes this trivial.
GCentral
(3,712 Views)
Thank you for your swift reply, worked a treat.
(3,701 Views)
I find it useful to think of deleting stuff from an array as creating a new array with only the stuff I want to keep.  Which is exactly what the code above is doing.  🙂
Bill
CLD
(Mid-Level minion.)
(3,680 Views)
