Deleting a group in a TDMS file increases the size of the file
Hello Everyone,
I have been searching information about how to delete a group in a TDMS file. Apparently this is not a simple task as I thought  since first it is necessary to convert the TDMS file into a TDM file, delete the group in the TDM file  and finally convert the TDM file into a TDMS file. There is a really nice example project here (I attached it in the post anyway!).
This project works nicely. Indeed I am able to delete the group of the TDMS file. Nevertheless I have realized that performing the deletion process increases the size of the file (approx. 4 times). If you visualize the TDMS file with the TDMS - File Viewer.vi you realize that several strange properties were added to each channel of all remaining groups. I supposed this is partially  the cause of the size increment.
Does anyone know why this is happening?
I am using LabVIEW 2014 and I downloaded the project for LabVIEW 2014.
Any help is higlhy appreciated.
Best Regards,
Diego Ballen
(5,015 Views)
I think it came out with LabVIEW 2015, but there is now a TDMS Delete Data Function.  This might do what you want.  You also might want to try to perform a TMDS Defrag on your file to see if that shrinks it down some.
GCentral
(5,009 Views)
(4,977 Views)
Accepted by DiegoBallen
The old way of doing it was to read out each group you want to save and write it to a new file. The basic problem is that the TDMS format was optimized for speed, and not memory efficiency, which can cause a lot of complications when doing seemingly simple stuff - like deleting data, or reading data out of the file.
This is why NI came up with these new functions. If you're stuck with an older version you can still write your own function to do the same thing.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,970 Views)
You could try an approach similar to the one I'm taking in a LV2013 project:
-Open the original tdms and read the data
-Said data becomes an array (string, double, boolean, etc.)
-Manipulate the data in whatever way you want (delete channel, data, etc.)
-Replace the original tdms with a blank one (create or replace)
-Write the manipulated data to the new blank tdms
(4,967 Views)
Thank you mikeporter and Daikataro!
I will take this approach and will generete simply a new file only with the data Im interseted in.
Greetings and thanks again!
Diego Ballen
(4,959 Views)
The files will get smaller and accessing the data in them will be faster because each group is not fragmented through out the file.
Mike...
LabVIEW Champion
(4,951 Views)
