Deleting a row from a table control through right-click menu
Yes you are right smercurio…! Thanks for the answer (for such an stupid question). I realized that a better strategy woulg be to clear the cell.
Thanks a lot!
Have a very nice day (or night as the case may be)!
Message 11 of 14
(857 Views)
Since the 'Empty Table' and 'Delete Row', etc. commands are 'Application Items', why is there any code necessary to utilize these?  In a similar vane, the 'Export' commands, which are also 'Application items', do not need underlying code from the programmer.  Is there an inconsistency here?
Message 12 of 14
(714 Views)
I just confirmed that if you use a table CONTROL, you should not need to add the the 'Table Control: Shortcut Menu Activation' event to your code.  The application items 'empty table' and 'delete row', etc., work just fine.  Not true for table indicator where even when the event is added to the code, these items will not work.  So there is a difference between table CONTROL vs. INDICATOR.   This is in LabVIEW 2010.
Don
Message 13 of 14
(710 Views)
2008 question being answered now!
Thanks anyway!
Message 14 of 14
(708 Views)
