Deleting array elements containing "999.0"
I have an array of 10 elements of DBL type. I would like to delete the element if it is of value 999.
For example the original array is [1.0   1.5   999   1.6   999   -6.9   0.0   999.0   4.7    -0.1] of size 10, the final array should be
[1.0   1.5   1.6   -6.9   0.0   4.7    -0.1] of size 7.
How to do this?
Message 1 of 12
(3,798 Views)
How about this code?
Message 2 of 12
(3,796 Views)
Hi GPeter could you please post it as a vi file?
Thanks..
Message 3 of 12
(3,792 Views)
Just to be sure, my code was built using:
- While loop
- Search 1D array
- Equal?
- Case structure
- Delete from array
Br,
Peter
Message 4 of 12
(3,791 Views)
Message 5 of 12
(3,789 Views)
Accepted by topic author splee
Hi Peter,
did you notice your RubeGoldberg-construct already?
One (slightly) improvement:
- Keep in mind: Using "Delete from Array" isn't very efficient when it comes to big arrays and a lot of elements to delete.
- Keep in mind: You get trouble really fast when trying to compare float numbers for equality. There are a lot of threads on this topic.
- Keep in mind: Search1DArray has an index input. This could help speed up the shown snippet.
Message 6 of 12
(3,788 Views)
Hi GerdW,
I tested your code but it doesn't work.. or maybe I was wrong?
Message 7 of 12
(3,783 Views)
Sorry, you have to swap TRUE and FALSE cases...
Message 8 of 12
(3,779 Views)
Try this.
Good luck
Message 9 of 12
(3,776 Views)
Ok both solutions work.. Thanks 🙂
But what's any flaw with GPeter solution?
Message 10 of 12
(3,772 Views)
