Dependency is broken
Version of usrp 2021 and modulation toolkit 2021. There is an entry in the registry. The error occurred spontaneously. The built-in block with the interpolator is broken, although I do not have access to it, because it is password protected. In addition, if you remove the interpolator, the broken arrow disappears, but when compiling, an error is generated in an unknown location.
I have a feeling that the scope in labview is broken, which is why all fpga dependencies are broken.
I had the same problem before and then I moved the project folder to the folder where all projects are saved in labview by default. However, now the project folder is already in this place, and the problem has appeared again
It is important to emphasize two details. 1 everything worked before. 2 I am convinced that I did nothing that could break everything
Message 11 of 11
(325 Views)
