Deploying RT Application
I wish to deploy a (functional) RT application on a cRIO platform.
However, in following the instructions on the following page, "Tools » Build Application or Shared Library (DLL" is greyed-out/disabled. If I open a fresh VI the button is enabled, but it is disabled on any of the existing VIs. The VI has been saved prior to trying to access this button.
http://www.ni.com/white-paper/3233/en
(2,859 Views)
Here is a screenshot of the menu option that is disabled. Why is this?
(2,829 Views)
Accepted by topic author ap8888
Problem is solved. Right clicking on "Build Specifications" within the RT tree works fine.
(2,812 Views)
