Deploying an exe for USB DAQ 6009
I am trying to develop an exe for USB DAQ 6009. The story is as follows;
I developed an exe on Vista, LV 8.5
I installed this exe on a W2000 PC with LV 8.5 RTE and it didn't work at all.
How can i deploy my exe to any W2000 PC, which RTEs or dlls or whatever is required.
As a next phase i'd like to develop a dll instead of my exe to run on Teststand 2.0
Any help is appreciated i'm stucked.
(3,143 Views)
This question has been asked and answered numerous times.
You need to include DAQmx when you create the installer (you did create an installer didn't you?). You might also have to include the hardware config from MAX.
(3,140 Views)
You probably didn't install the DAQmx drivers - the drivers to handle the communication with the DAQ cards as Denis pointed out. It would be helpful if you elaborated little bit more on what errors you are receiving otherwise we can only speculate.
LV 2011, Win7
(3,128 Views)
