Dequeue element freezes (timeout = 0)
Random suggestion - have you tried putting a 'get queue status' in front of or in parallel to the dequeue? Very strange..
Message 11 of 18
(2,571 Views)
Ty, I haven't but I'll try when as soon as get the chance.
I realize though that I haven't posted about one other attempt to understand the problem:
When the Dequeue was frozen, I ran a VI that obtained this queue by name and enqueued one element. That then released the frozen dequeue.
Message 12 of 18
(2,548 Views)
Strange indeed. It behaves like you've wired -1 to timeout. Have we found a bug?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 18
(2,538 Views)
What version of LabVIEW are you using? The behavior sounds a lot like CAR 677003 which was fixed in a 2017 SP1 patch.
http://www.ni.com/product-documentation/54421/en/
Message 14 of 18
(2,520 Views)
I'm using LabVIEW 2017 32-bit (17.0.0) so that as well may be the issue. I'll do an experiment with SP1.
Thank you!
Message 15 of 18
(2,505 Views)
Interesting.  We've observed the opposite.
When reading from a DMA channel on RT systems, we wire in timeout -1, non-zero requested number of elements, the node has no data, returns immediately with no data, no error.  This is a combination of performance and parameters which should not co-exist.
Message 16 of 18
(2,487 Views)
Possibly related to CAR 611315? Sounds like similar symptoms but I'm not sure whether DMA FIFOs and Queues share implementation details so you would have to call in to support and have them ask R&D if it's important for your project.
http://www.ni.com/product-documentation/53294/en/
Message 17 of 18
(2,424 Views)
I don't think they're linked to that CAR.  We only have a single timeout ever wired to our DMA read.  IIRC, it was a bug in the RIO drivers which apparently got patched after we reported a way to reproduce the issue.
Message 18 of 18
(2,403 Views)
