Derivative and dt trouble
Hello everybody. I would ask you why if I use the Derivative belonging to the Time Domain Math (it concerns dynamic data type) I can subctract a waveform with an another one keeping the same dt and why,on the other hand, if I use the "normal and typical" Derivative  I cannot do the same subtraction due to "a different dt between the two waveforms" Error.
Thank you in advance.
(2,785 Views)
Moreover, I checked the dt values of the two waveforms: they are the same.
(2,775 Views)
Hi Edmond,
as usual: attach an example VI...
(2,761 Views)
