So by asking more questions about my question, are you implying you don't know if it's harmless or not? Yikes 😞
Which "shipping" examples are you referring to?
Luckily, there aren't any errors when I'm using the VI. The only strange behavior is that sometimes Labview will crash with 0xC0000005 if I hit stop and then I hit run again within a few seconds. I guess sometimes labview needs to rest?
I'm using Labview 2013 and DAQmx 9.7.5. Below are the software installed on this machine. Thanks.
Spoiler (Highlight to read) Name Version Advanced Signal Processing Toolkit 13.0.0 C Series Module Support 13.0.0 Common 12.0.20.258 Common 13.0.35.190 Common 13.0.40.190 Common 13.0.40.190 Common (64-bit) 13.0.35.190 Common (64-bit) 13.0.40.190 Common (64-bit) 13.0.40.190 CompactRIO 13.0.0 Configuration Support 2.9.3 Configuration Support 1.8.5 Configuration Support 2.7.5 Configuration Support 1.9.5 Configuration Support 4.0.5 Core 13.0.0.242 Core 13.0.0.242 Core 13.0.0.242 CVI 13.0.0 CVI AddOns LabWindows/CVI Shared AddOns CVI Run-Time 13.0.0.632 Database Connectivity Toolkit 13.0.0 DataSocket 13.0.35.242 DataSocket 13.0.40.242 DataSocket 13.0.45.242 Design 13.0.35.242 Design 13.0.40.242 Design 13.0.45.242 Design (64-bit) 13.0.35.242 Design (64-bit) 13.0.40.242 Design (64-bit) 13.0.45.242 Development Support 2.9.3 Development Support 1.8.5 Development Support 2.7.5 Development Support 1.9.5 Development Support 4.0.5 Digital Filter Design Toolkit 13.0.0 DMM Soft Front Panel 3.1.0 DotNET DotNET DotNET DotNET FGEN Soft Front Panel 2.7 Gpib 13.0.35.159 Gpib 13.0.40.159 Gpib 13.0.45.159 Gpib (64-bit) 13.0.35.159 Gpib (64-bit) 13.0.40.159 Gpib (64-bit) 13.0.45.159 Image Processing and Machine Vision 13.0.0.49156 Integration 13.0.35.242 Integration 13.0.40.242 Integration 13.0.45.238 IVI Compliance Package 4.6 LabVIEW 13.0.0 LabVIEW Run-Time 2010 SP1 10.0.1 LabVIEW Run-Time 2011 SP1 f2 11.0.1 LabVIEW Run-Time 2012 SP1 f3 12.0.1 LabVIEW Run-Time 2012 SP1 f3 (64-bit) 12.0.1 LabVIEW Run-Time 2013 13.0.0 LabVIEW Run-Time 8.5.1 8.5.1 MathScript RT Module 13.0.0 Measurement & Automation Explorer 5.5.0f0 Measurement Studio Visual Studio 2005 Support - See individual versions below. Measurement Studio Visual Studio 2008 Support - See individual versions below. Measurement Studio Visual Studio 2010 Support - See individual versions below. Measurement Studio Visual Studio 2012 Support - See individual versions below. NationalInstruments.DAQmx 9.6.35.292 NationalInstruments.DAQmx 9.6.40.292 NationalInstruments.DAQmx 9.6.45.292 NI FlexRIO 13.0.0f0 NI I/O Trace 3.1.0f0 NI Motion Assistant 13.0.0 NI PXI Platform Services 3.2.3 NI R Series Multifunction RIO 13.0.0 NI Script Editor 1.3.4 NI SignalExpress 7 NI SoftMotion 13.0.0 NI System Configuration 5.5.0f0 NI TestStand 5.1 NI Vision Run-Time 13.0.0 NI-488.2 Software 3.1.1 NI-DAQmx ADE Support 9.7.5 NI-DAQmx Device Driver 9.7.5f1 NI-DAQmx MAX Configuration 9.7.5 NI-DCPower NI-DCPower Soft Front Panel 1.8.5 NI-DMM 3.1.0 NI-FGEN NI-HSDIO 1.9.5.0 NI-HWS 1.5.1 NI-IMAQ I/O 2.7.0 NI-IMAQ Software 4.7.3 NI-IMAQdx 4.2.0 NI-Motion 8.5.0.3000 NI-PAL Software 2.9.1 NI-RFSA NI-RFSA Soft Front Panel 2.6.1 NI-RFSA Soft Front Panel (Classic) 2.5.2 NI-RFSG NI-RFSG Soft Front Panel 1.9.5 NI-RIO 13.0.0 NI-SCOPE NI-Serial Software 4.0.0 NI-SWITCH 4.6.5f0 NI-Sync 3.4.0 NI-TClk 1.9.3 NI-USI 2.0.1.5249 NI-VISA 5.4 NI-VISA Runtime 5.4 NIvisaic.exe 5.4.0.49152 NiVisaServer.exe 5.4.0.49152 PID Control Toolkit 13.0.0 PID Toolkit 2.1.0 Profiler Toolkit 1.0.0 Real-Time 13.0.0 Report Generation Toolkit For Microsoft Office 13.0.0 Run-Time 2.9.3 Run-Time 1.8.5 Run-Time 2.7.5 Run-Time 1.9.5 Run-Time 4.0.5 SCOPE Soft Front Panel 4.0.5 Services 13.0.0.49156 Signal Processing Toolkit 7.0.2 Soft Front Panel 4.6.5.49152 SQL Toolkit 2.2.0 System Identification Toolkit 2013 Tdms 13.0.35.242 Tdms 13.0.40.242 Tdms 13.0.45.242 Tdms (64-bit) 13.0.35.242 Tdms (64-bit) 13.0.40.242 Tdms (64-bit) 13.0.45.242 UI 13.0.35.242 UI 13.0.40.242 UI 13.0.45.242 UI (64-bit) 13.0.35.242 UI (64-bit) 13.0.40.242 UI (64-bit) 13.0.45.242 UI.WebForms 13.0.35.242 UI.WebForms 13.0.40.242 UI.WebForms 13.0.45.242 UI.WebForms (64-bit) 13.0.35.242 UI.WebForms (64-bit) 13.0.40.242 UI.WebForms (64-bit) 13.0.45.242 Unit Test Framework Toolkit 13.0.0 VI Analyzer Toolkit 13.0.0 Visa 13.0.35.167 Visa 13.0.40.167 Visa 13.0.45.167 Visa (64-bit) 13.0.35.167 Visa (64-bit) 13.0.40.167 Visa (64-Bit) 13.0.45.167 Vision 13.0.20.101 Vision 13.0.35.101 Vision Builder AI 5.0.3 Vision Development Module 13.0.0 WPF.Controls 13.0.40.242 WPF.Controls 13.0.45.242 WPF.Controls (64-bit) 13.0.40.242 WPF.Controls (64-bit) 13.0.45.242 WPF.Controls.Design 13.0.40.242 WPF.Controls.Design 13.0.45.242 WPF.Controls.Design (64-bit) 13.0.40.242 WPF.Controls.Design (64-bit) 13.0.45.242
Name VersionAdvanced Signal Processing Toolkit 13.0.0C Series Module Support 13.0.0Common 12.0.20.258Common 13.0.35.190Common 13.0.40.190Common 13.0.40.190Common (64-bit) 13.0.35.190Common (64-bit) 13.0.40.190Common (64-bit) 13.0.40.190CompactRIO 13.0.0Configuration Support 2.9.3Configuration Support 1.8.5Configuration Support 2.7.5Configuration Support 1.9.5Configuration Support 4.0.5Core 13.0.0.242Core 13.0.0.242Core 13.0.0.242CVI 13.0.0CVI AddOns LabWindows/CVI Shared AddOnsCVI Run-Time 13.0.0.632Database Connectivity Toolkit 13.0.0DataSocket 13.0.35.242DataSocket 13.0.40.242DataSocket 13.0.45.242Design 13.0.35.242Design 13.0.40.242Design 13.0.45.242Design (64-bit) 13.0.35.242Design (64-bit) 13.0.40.242Design (64-bit) 13.0.45.242Development Support 2.9.3Development Support 1.8.5Development Support 2.7.5Development Support 1.9.5Development Support 4.0.5Digital Filter Design Toolkit 13.0.0DMM Soft Front Panel 3.1.0DotNET DotNET DotNET DotNET FGEN Soft Front Panel 2.7Gpib 13.0.35.159Gpib 13.0.40.159Gpib 13.0.45.159Gpib (64-bit) 13.0.35.159Gpib (64-bit) 13.0.40.159Gpib (64-bit) 13.0.45.159Image Processing and Machine Vision 13.0.0.49156Integration 13.0.35.242Integration 13.0.40.242Integration 13.0.45.238IVI Compliance Package 4.6LabVIEW 13.0.0LabVIEW Run-Time 2010 SP1 10.0.1LabVIEW Run-Time 2011 SP1 f2 11.0.1LabVIEW Run-Time 2012 SP1 f3 12.0.1LabVIEW Run-Time 2012 SP1 f3 (64-bit) 12.0.1LabVIEW Run-Time 2013 13.0.0LabVIEW Run-Time 8.5.1 8.5.1MathScript RT Module 13.0.0Measurement & Automation Explorer 5.5.0f0Measurement Studio Visual Studio 2005 Support - See individual versions below.Measurement Studio Visual Studio 2008 Support - See individual versions below.Measurement Studio Visual Studio 2010 Support - See individual versions below.Measurement Studio Visual Studio 2012 Support - See individual versions below.NationalInstruments.DAQmx 9.6.35.292NationalInstruments.DAQmx 9.6.40.292NationalInstruments.DAQmx 9.6.45.292NI FlexRIO 13.0.0f0NI I/O Trace 3.1.0f0NI Motion Assistant 13.0.0NI PXI Platform Services 3.2.3NI R Series Multifunction RIO 13.0.0NI Script Editor 1.3.4NI SignalExpress 7NI SoftMotion 13.0.0NI System Configuration 5.5.0f0NI TestStand 5.1NI Vision Run-Time 13.0.0NI-488.2 Software 3.1.1NI-DAQmx ADE Support 9.7.5NI-DAQmx Device Driver 9.7.5f1NI-DAQmx MAX Configuration 9.7.5NI-DCPower NI-DCPower Soft Front Panel 1.8.5NI-DMM 3.1.0NI-FGEN NI-HSDIO 1.9.5.0NI-HWS 1.5.1NI-IMAQ I/O 2.7.0NI-IMAQ Software 4.7.3NI-IMAQdx 4.2.0NI-Motion 8.5.0.3000NI-PAL Software 2.9.1NI-RFSA NI-RFSA Soft Front Panel 2.6.1NI-RFSA Soft Front Panel (Classic) 2.5.2NI-RFSG NI-RFSG Soft Front Panel 1.9.5NI-RIO 13.0.0NI-SCOPE NI-Serial Software 4.0.0NI-SWITCH 4.6.5f0NI-Sync 3.4.0NI-TClk 1.9.3NI-USI 2.0.1.5249NI-VISA 5.4NI-VISA Runtime 5.4NIvisaic.exe 5.4.0.49152NiVisaServer.exe 5.4.0.49152PID Control Toolkit 13.0.0PID Toolkit 2.1.0Profiler Toolkit 1.0.0Real-Time 13.0.0Report Generation Toolkit For Microsoft Office 13.0.0Run-Time 2.9.3Run-Time 1.8.5Run-Time 2.7.5Run-Time 1.9.5Run-Time 4.0.5SCOPE Soft Front Panel 4.0.5Services 13.0.0.49156Signal Processing Toolkit 7.0.2Soft Front Panel 4.6.5.49152SQL Toolkit 2.2.0System Identification Toolkit 2013Tdms 13.0.35.242Tdms 13.0.40.242Tdms 13.0.45.242Tdms (64-bit) 13.0.35.242Tdms (64-bit) 13.0.40.242Tdms (64-bit) 13.0.45.242UI 13.0.35.242UI 13.0.40.242UI 13.0.45.242UI (64-bit) 13.0.35.242UI (64-bit) 13.0.40.242UI (64-bit) 13.0.45.242UI.WebForms 13.0.35.242UI.WebForms 13.0.40.242UI.WebForms 13.0.45.242UI.WebForms (64-bit) 13.0.35.242UI.WebForms (64-bit) 13.0.40.242UI.WebForms (64-bit) 13.0.45.242Unit Test Framework Toolkit 13.0.0VI Analyzer Toolkit 13.0.0Visa 13.0.35.167Visa 13.0.40.167Visa 13.0.45.167Visa (64-bit) 13.0.35.167Visa (64-bit) 13.0.40.167Visa (64-Bit) 13.0.45.167Vision 13.0.20.101Vision 13.0.35.101Vision Builder AI 5.0.3Vision Development Module 13.0.0WPF.Controls 13.0.40.242WPF.Controls 13.0.45.242WPF.Controls (64-bit) 13.0.40.242WPF.Controls (64-bit) 13.0.45.242WPF.Controls.Design 13.0.40.242WPF.Controls.Design 13.0.45.242WPF.Controls.Design (64-bit) 13.0.40.242WPF.Controls.Design (64-bit) 13.0.45.242
