wrong graph
I am not getting the right graph.
Message 1 of 15
(6,439 Views)
I don't get the right graph too with missing subVIs and missing data files…
Maybe you should try to explain your problem in more detail?
Message 2 of 15
(6,430 Views)
well i am just trying to read my data i imported into a TDMS file. Here are the subvis sorry.
Message 3 of 15
(6,424 Views)
Message 4 of 15
(6,413 Views)
What do you mean by the wrong graph? Can you see the correct data with the TDMS browser VI?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 15
(6,375 Views)
The graph is suppose to show the data that is in the tdms file but instead it gives me a really large amplitude that is wrong. the waveform is not being shown correctly and the number on the x axis should be in the lower 4000's.
Message 6 of 15
(6,346 Views)
The TDMS file is correct as I was able to tell by looking at it with the TDMS viewer VI.
The problem was the reader. I have no idea what you were doing but the attached is all you need.
Mike...
LabVIEW Champion
Message 7 of 15
(6,335 Views)
I knew how to do that but I want it to work with this program where 4060 would be the number of ms on the x-axis and of course the amplitude on the y-axis. I want the read data to be converted into an array so i can display it on this graph and potentially take the derivative of the waveform.
Message 8 of 15
(6,323 Views)
Well the data is an array, and it is displayed on a graph. In terms of generating an X axis, the reciprocal of the sample rate is the time between samples. What more do you want?
Mike...
LabVIEW Champion
Message 9 of 15
(6,307 Views)
Now i get the wrong data at the end of display one electrode.
Message 10 of 15
(6,275 Views)
